Cougarnewbie's avatar
Cougarnewbie
Broken Lippert weld? 2005 Cougar
I just noticed that with the fiver unhooked I have a separation on the curb side near the front cap. The material under the overhang surrounding the king box is dropping away about 3/4 of an inch where it meets the side. The scary part is that when I hook up the truck and put weight on the king box it closes up. I took down the trim insert on the underside and tightened the screws. It closed up a little but not much. I fear a broken weld up in the framing. Any thoughts or suggestions? I will try to post pictures.
Thanks
AL
  • I have had 3 fivers and not one with a Lippert frame, I am on the forum consistently and read these frame issues and wonder why consumers continue to buy products that are inferior at the start. I guess it is best to just keep posting these problems and complaining maybe someone at Lippert will decide that it is time to stop the nonsense. Just because some people want a particular layout or are limited in the level of quality they can afford doesn't mean that they should get an inferior product. The manufacturers using the frames are the ones who can put the pressure on Lippert, but worry about pricing themselves out of a section of the market. Too Bad we settle for good enough.
  • Find a good welding shop and make sure they brace it with extra metal. I've had several Lippert frames and know they are made pretty cheap.
  • Not good...who needs this kind of grief.
    If you go to the link below you will see many examples of failed welds on frames...and how they were fixed.
    Probably going to be a trip to a local welding outfit.
    Broken Frame Images...LINK
