Gray_Fox's avatar
Gray_Fox
Broken Spring
We got home with the broken spring 175mi no problem, We
took it to a spring shop in Prov. R I an they replaced both spring on
the same side new bolts an shackles. I may do the other side before we
leave for Mich. next spring, all winterize for now..
  • My replacement springs came from these guys, installed by my local Big O tire shop:
    http://www.aaaspring.com/
  • memtb wrote:
    The second spring has found a semi-permanent home residing in the bed of our truck.
    On another forum an RV'r posted regarding the difficulty he once had when he had a broken spring while traveling and could not easily find the correct size. From that point on he ensured that springs were part of his spare parts inventory.
    In trying to learn from others, I have done the same, and 2 spares with bronze bushings inserted reside under our bed in the RV.
  • Jerry, you left out “wannabe”.....as in, wannabe Wyoming rancher/cowboy! ;) memtb
  • memtb wrote:
    In more than 30 yards of rv’ing, we’ve experienced 3 broken springs.....two in the last 3 years. Two of these were on while on the road. The most recent, discovered when making my “walk-around” while doing an afternoon refueling at a truck stop 50+ miles south of Lincoln, Ne. We spent the night in the truck stop while a cold front pushed-through, setting a low temperature record in Lincoln. The next morning we drove into Lincoln (after getting permission to leave the 5er in the lot), and bought 2 springs. I replaced the spring (it was cold work)and we were back on the road by 10:00or so. The second spring has found a semi-permanent home residing in the bed of our truck. We should “never” break another.....as we are now prepared.
    It seems that our repairs always happen during somewhat “extreme” temps. :M The previous spring change was done in an asphalt parking lot in Mesa, Az.....in August! I did that repair in early morning, while it was a little cooler....but rapidly getting hot. I was very thankful for the large piece of “Astro-turf”, I keep for putting on tire chains ( mud or snow), which helped “insulate” me from the hot asphalt!
    And then, there was that wheel bearing / brake assembly replacement during the Christmas Holidays, several years ago. Done in a campground, with morning temperatures below 0F. That required more than one cup of “hot chocolate”!
    Rv’’ing can certainly be an adventure ! We should write a book! memtb
    Lol, an adventure for a tough Wyoming rancher/cowboy, but a nightmare for some of us softer city boys. :B Good for you, to tackle these jobs, get er done, and back on the road!!
    Jerry
    Adventures for sure, Todd!
    I had our springs replaced after our May-June 5200 mile road trip. US-made with a heavier rating and raised the rig between 4 and 5”. Next spring, after the winter season parked in Mesquite, NV, I’ll have wet bolts installed.
  • In more than 30 yards of rv’ing, we’ve experienced 3 broken springs.....two in the last 3 years. Two of these were on while on the road. The most recent, discovered when making my “walk-around” while doing an afternoon refueling at a truck stop 50+ miles south of Lincoln, Ne. We spent the night in the truck stop while a cold front pushed-through, setting a low temperature record in Lincoln. The next morning we drove into Lincoln (after getting permission to leave the 5er in the lot), and bought 2 springs. I replaced the spring (it was cold work)and we were back on the road by 10:00or so. The second spring has found a semi-permanent home residing in the bed of our truck. We should “never” break another.....as we are now prepared.
  • I'd do the other side, the springs on both side are the same age. Springs, brakes, bearings: do all at the same time.
  • glad you got back and got ll fixed up... Probably a good idea to look into the other side before next years trip....
  • Which camp do you inhabit? If one spring is weak, so is the other. Or one spring was faulty?
