Defiantly will keep you all posted. I can say the demo was fun!! My friend has property where we did it. He has an excavator with a thumb that made short work of it, we had it completely stripped in 3 hours. I have already done a lot of research and watched a lot of you tube. I plan to use more conventional building techniques with a mix of metal and wood stud walls with a shallow hipped roof at the front and a gable at the rear. I'm redoing everything from the ground up... started with new bushings in the spring packs and surprised the brakes and axles are in good shape. Already have put a material list together and surprisingly it's not too expensive. I already have shortened the frame by 4 feet so it fits in my driveway nicely where I have a rv hookup. From front to back I'm at 28 feet. I'm also going with thicker floors than what was there. I'm going retro and building it with no slide outs as my previous rv experience's have been more of just "one more thing to worry about". Weight is always a concern so I will be watching this closely. I do have a few surprises as the build progresses...I will throw some pictures out there soon.
