Define "taking out"? Does that mean burned out filament? Shorts, loose crimps, and/ or loose or poor contacts on sockets don't burn out bulbs, excessive voltage does. Think about it.. You cannot possibly generate enough heat in a poor connection to burn out a lamp that's already burning white hot. What you will do is cause a fire. Get a volt meter and look at the LOADED voltage at the fixture, with the lamp installed. That means you will need to gain access to the +&- feeds at the fixture.
Or just replace it with a regulated LED and solve several problems.
