- webslaveExplorerI tow with the rig in my signature. Short bed (6'6") and use the B&W Companion. No slider needed and I can get 90 degrees if I have to, but, I've never put myself or found myself in the situation where I had to. My Cougar has rounded corners and I could get to 90 degrees before I changed the pin box to the TrailAir Tri-Glide unit, and now, can probably get a little more than 90 since the TrailAir pinbox is ~6" longer than the stock pinbox which pushes the front of the trailer back by that much.
- TrooperTaylorExplorer
MatcoMN wrote:
I pull my trailer with a regular companion hitch, with a 6.6' crew cab truck with no issues
How sharp can you turn? - Robin1953ExplorerI have never towed a fifth wheel with a short bed. I have had a long bed truck when I had the fifth wheels. BUT if I had a short bed truck I would spring for the slider hitch. Things like that are not worth it to me to have to be sweating bullets whenever I make a turn. JMHO
outback_06 wrote:
I have a 2014 F250 with the turn over ball mount. Trying to decide if I need the slider with the B&W companion hitch. Any experience out there?
Thanks
I'm in the same boat as your are. I have a 2012 ram 2500 with a turnover ball. 6'5" measured from the back of the cab to the inside of the tailgate.
Most people say I don't need a slider hitch because of the extended pin box and rounded corners.
I haven't purchased the 5er yet but probably will tomorrow. So kinda in a jam about the hitch. - MatcoMNExplorerI pull my trailer with a regular companion hitch, with a 6.6' crew cab truck with no issues
- sdetweilExplorerwhat trailer do you have? some have nice rounded corners, some don't.
haven't heard of anyone using the B&W Slider.. but they must have made it for a reason.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
