goducks10
Apr 09, 2018Explorer
From the top of the jaws to the top of the hitch is 2.5".
From the bottom of the pin to the underside of the pin box is 3.5"
If you high hitch the bottom of the pin box is sitting 2" higher than the top of the 5th hitch. That would be so obvious I'm not sure how someone could actually not notice it. Plus like already mentioned, if you're using the B&W correctly then you've pulled the handle back towards the cab and when the pins locked in the handle moves forward as you back in.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
