laknox
Apr 10, 2018Nomad
billyray50 wrote:john&bet wrote:4x4ord wrote:I have something simpler. t is a Reese Goosebox pin Box Adapter. When you unhitch only thing left is a ball in your bed.
The B&W for the Ford puck system must be smaller and lighter than the one for the Ram. It can be installed and removed in two pieces and is very easy for one person to handle. I can't imagine anything being much simpler.
Interesting about Reese Goosebox adapter. When looking it up I saw this too. E Z lift RV fifth wheel to gooseneck adapter. Any input on this type of setup?
A "traditional" GN/FW adapter =may= void the warranty on many FWs; you need to check with the mfr., NOT the dealer, to find out. The Goosebox is about the only adapter that some mfrs. will not void a warranty over, and Lippert says won't void a frame warranty. Of course, Lippert makes about 80% of all frames used =and= owns Reese, soooo...
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
