For you folks that have this hitch. I just installed one on my new to me TV. The operating instructions where not much help in lubrication of this hitch. It has 1 (one) zerk fitting on the side to si...
You must grease the heads of the two arms that the hitch head sits on when you attach it to the base. You also have to make sure your pin is greased so that it will rotate freely in the jaws of the hitch. Use any automotive or marine grease. Most people use a teflon pad so the top face does not need grease.
