sdetweil
Nov 03, 2014Explorer
JamesBr wrote:
I have used the B&W patriot on a friends truck, the dual jaw design is similar to the reese version. For a short person I found the handle actuator actually very difficult to use as I would have to jump on the tires to use it. Otherwise, the hitch worked well and locked in, no different then other 2 jaw deigns.
In my truck I have the Pullright ISR (ISR uses standard 5th wheel rails like the patriot.) I like it because I can reach the release and pull it towards me, no need to climb the truck. I have no had any issues with high hitching because if the king pin is too high the Pullright would not activate and latch. The jaw circles the entire kingpin and locks well into place and it cannot pop loose once you place a pad lock or carabiner to lock the release handle in the latched state. I use a carabiner for that as well as the place to secure my emergency brake cable.
One intersting thing with the pullright, if there is any pressure on the jaw you cannot pull the release handle, so I always have to remember to chock the trailer and bump backwards before disconnecting.
I am 6'2", and have a 2012 ford Dually.. and cannot reach the handle on my Patriot without some assistance. I use a 3 step stepladder and climb over the rail. (vs get wet when its raining)
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
