CoMoCo's avatar
CoMoCo
Cabinet door - how to tighten catch
One of the catches on a cabinet door seems loose when you open the door. I thought there was a way to tighten the catch - is there?
On edit: To clarify, it is very easy to open the cabinet door. What I would like to do is pinch the rollers together so it is harder to open the cabinet door. I hope this makes more sense.
Here is a picture of the double roller catch that we have.
Thanks for your help!
  • Can you take a pair of pliers and pinch the rollers closer together? Or perhaps you can spread the part that gets pinched by the rollers, again using pliers?
  • To clarify, it is very easy to open the cabinet door. What I would like to do is pinch the rollers together so it is harder to open the cabinet door. I hope this makes more sense.
  • Not sure which way it is loose but you'll note the roller assembly has slots which would mean that is the adjustable portion of the assembly.
