Dandy_Dan
Jan 30, 2015Explorer
Bill, I have had an Open Range since May of 2008 and have had no trouble at all with any of our 3 slides. The cable system will take around 200-250 pounds per slide off the weight. Here is the link you can copy and paste. www.norcoind.com/bal/products/oem/accuslide/index.shtml Good luck in your decision on these but more companies are going to them.
If folks are getting cutting then one of two reasons for that can be
1) Improper adjustment or 2) The slide was jigged out of square when the framework was put together and welded. This will also cause rubber cutting.
About Fifth Wheel Group
