EgorKC's avatar
EgorKC
cable splitter location
We have a 2013 Forest River Wildcat Rear Living 5th wheel. Cable TV has never worked great but has been much worse the last 4-5 years, If I run Cable from Campground post direct through window to any TV reception is perfect. Through the main 5er cable input it is very snowy. I replaced the Antenna power boost outlet and removed all 4 of the Cable hookups and verified a tight connection. I also checked the main Cable input to verify tight. No change in snow. None of these have a splitter connected to the cable. I pulled all lines out as far as they had slack and no splitter. I then removed every access panel in the main trailer and basement to look for a main cable splitter. NO luck. There has to be one somewhere as this trailer has 1 cable inlet and 4 cable outlets. Does anyone have any idea where it could be? I will contact Forest River but my understanding from research is that RV's are wired based on the whim of the crew that given day. Thus I expect no real help there. We can use antenna reception but DW prefers the cable variety. Hoping to get help narrowing down the hunt.
Greg
