Atom Ant wrote:
The cable system makes me shudder when I think back to rethreading cables on my Starcraft popup years ago, but I really don't have any experience with them.
What I do have experience with is Schwintek (rack and pinion as you call it) on our forward slide and it is not great either. I have to keep it lubed, or it shuts off before the slide is actually closed, and it just sounds fragile. I'll take hydraulic anytime, but I understand with the new front living rooms and taller slides it is not always reasonable to install a hydraulic piston under the slide.
That hydraulic piston requires a hole be put in the beam. The hole itself becomes an engineering liability. By eliminating the hole designers can eliminate a lot of weight. That is the ultimate advantage of the cable system.
Otherwise both systems are mechanical with moving parts and motors that can,will and break occasionally.
Nether system is foolproof but creating a significant weight reduction is a huge bonus for the cable slides
