flyinjake's avatar
flyinjake
Cables and Pulleys on Slides
Looking at 5ers and one of the models we are considering uses a cable and pulley system rather than rack and pinion or hydraulic to extend or retract the slides. My current TT has the R&P and it seems most have the R&P system. I have also seen the hydraulic systems but mainly in the higher end models. Does anyone have experience or thoughts, good or bad, with the cable and pulley system?
Thanks
Jake
  • I've been using it for a little over a year. It was recommended that I wipe down the cables in the spring to clean and check for fraying. This system had some problems a few years back but the mfg's seem to have worked that out. I can send you to an owners forum for my brand, but you can probally locate it or the brand you are looking at with a quick google search. Good luck with your choice which ever way you go, but I'm happy with mine.
