Me_Again
Jun 16, 2020Explorer III
Actual the wall plate with the TV booster is a power supply for the booster that is in the antenna itself. This power supply also has a splitter and electric switch between cable input and OTA antenna input. To use the antenna the light has to be on indication it is sending the 12V DC to the booster in the antenna. The the TV has to be on TV and a channel scan has to be done to picked the channels in any given location. The two trailers that we currently have the power supply is in the bedroom.
The backside of the power supply has three coax connections. Cable in, Antenna in, and splitter output. The front has a second splitter output.
(Moderator edit to increase picture size)
About Fifth Wheel Group
