Petethescot's avatar
Petethescot
Cameo f35sb3 Tv antenna booster
Hi All newest problem,
Cannot get any channels using the antenna. I have been on roof disconnected coax up there and did a connectivity test behind tv. All is good there but I do not seen to have a booster switch or else I can’t find it. Not sure if that is issue.
Btw antenna is one of those circular multi directional so should not have to rotate antenna.
Any suggestions
Thanks again
Peter
  • rv antenna,s are very poor most have a booster, find the cable at the tv and follow it. we took the org tv out put one in with a dvd player. our booster was in a cabinet you push a button to turn it on/off.
