Bunklash's avatar
Bunklash
Cameo low water flow
Over the last couple of years, the cold water pressure at the kitchen sink has diminished. The problem is only at the kitchen faucet, and only the cold water. My first guess is that I have a clogged filter, but cannot locate one. It is on the unit in my signature. Can anybody help me out?
Thanks in advance
  • IF it only the cold side of faucet (hot flow OK) then it isn't aerator it is the cold side of faucet clogged up.
    Need to disassemble faucet (IF possible..RV faucets are junk) and clean.
    OR replace with a good quality residential faucet
    If you had a water filter and kitchen sink is only faucet that is problem then filter would be under kitchen sink with cold water line to faucet.
  • If it's really just that one faucet, I'd take the stem out and see if some crud is blocking the seat or even the supply connector under the counter. Craig
