- 301TBSExplorerI have a Crossroads product and quite like it. I realize its just an inexpensive model, but we all can't afford to own more expensive products. There is no need to put them down.
- lillyputzExplorer II
mobilcastle wrote:
pcm1959 wrote:
rmalik1 wrote:
Don't know if its been posted but Crossroads RV is bringing the Carriage and Cameo nameplate back.
Don't be fooled I looked at the the construction info and it ain't no Carriage of old (Lifestyles is)
Don't get excited. Its just another junky Thor/Crossroad product. Nothing about it even close to being like an original Carriage OR Lifestyle.
There is no reason to bad mouth anyone's 5ver. Thor now owns DRV. Do you consider them junk? Many believe they are a step up from your unit.
I believe, what they are refering to on some of the construction is. The old Carriage and Lifestyle use a box frame with over the floor slide mounting, similar to DRV. Not a I-beam, that has holes cut in it for the slide rails. The box frame won't twist or flex like the I-beam frame does.
Lillyputz - sk734Explorer
There is no reason to bad mouth anyone's 5ver. Thor now owns DRV. Do you consider them junk? Many believe they are a step up from your unit. - pcm1959Explorer II
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
