time2roll
Aug 24, 2019Nomad
You should be good to go with the 68100. The voltage should drop to 13.6 in about 4 hours of 14+ and then with minimal use should drop again to 13.2 volts in a few days.
If you are expecting a fast charge and charging voltage is below 13.7 give a push on that boost button on the front.
Although since it is a WFCO it is best to monitor things periodically.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
