laknox
Apr 24, 2018Nomad
patperry2766 wrote:
Considering upgrading in the next couple of years and trying to decide between a 5th wheel and tow a small trailer behind (ATV's/motorcycle, etc) or just to get a toyhauler.
Are all 5's capable of doing this, or are there some particular brands or models that are better suited for this task that have a more robust frame, axle set-up, etc?
What questions/info should I be seeking from the manufacturers?
If I do choose a toyhauler, how do most people transport their toys to the play area if it's not immediately accessible to the campground, or if it's a vehicle than can't be legally driven on the roads?
In a word, NO! Most FWs have frames that are too light to safely tow much of anything if you do put a hitch on them. There are a lot of mfrs now that =are= offering hitches as an OEM option (some even standard), but almost all are limited to a 300 lb hitch / 3k GVW trailer. This is because virtually all states have a 3k limit on utility trailers that do not need brakes. At > 3k on the placard, you are required to have brakes. Now, you can =modify= a FW to have a heavier hitch, but it will almost certainly void any warranty on the frame. If you go this route, there are plenty of DIY threads on here showing how to do a =proper= job of adding a hitch.
Add to this, that it's not legal to tow doubles in all states. Something like 28 states do not allow it, though lots of people report that they've done it for "years" without a hassle. Roll da bones; takes your chances.
Length was mentioned. In AZ, total length is 65' from front bumper to rear axle. You =can= have up to 10' of "overhang" from the rear axle, which gives you an effective OAL of 75'. I know a lot of RVers and not a one has been stopped. (shrug) Again, roll dem bones...
Someone mentioned the swivel-wheel type extensions and DutchmenSport said that, in IN, they are treated as trailers. Many other states also treat them as trailers so, if you get nailed, you've got to find some way to unhook it and either leave it on the side of the road or have it loaded on a trailer to move to the state line.
You really need to think about where you want to go and how you're going to get there AND how much risk you're willing to take if you tow through a known "no doubles" state.
Lyle
About Fifth Wheel Group
