bfast54
May 07, 2016Explorer
fj12ryder wrote:bfast54 wrote:Seems like the best thing to do is search for the 2010 model. :)
Well they're out of business so maybe that had something to do with it?????
you could get a hold of Lippert Corporation as I'm sure they made their frames ---and find out what the specs were for that unit .
then get with MOR-RYDE Elkhart Indiana, and see if they can install one of their heavy duty suspensions---- problem solved.
You Would still be stuck with a very heavy rig, and under rated axles .
Mor/ryde has the solution they custom make suspensions they put them onSelect Suites And other rings made by that company ----those are heavy as heck !!!
so if the frame can take it --Mor-Ryde would have the suspension that would cure the other issue( and of course the bigger tires to go with it).
I toured the mor-ryde Factory couple weeks ago ---they are the cat's meow
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
