janegowest
May 10, 2016Explorer
Allworth wrote:
Jane,
Look back at some of your (many) questions...
Can you change tank sizes?
Can you change CCC?
Can you change kitchen layout?
I know you are trying to figure all of this out, but I really think you should worry less about changing things and look harder for a unit that you can accept as it is.
Compromises are necessary, but the right unit for you is out there somewhere.
A
Thank you. One correction....I don't recall asking about changing kitchen layout...as that is set in stone. It was the furniture layout in the LR.
One has to consider changes when one is limited to used units that don't smell and we can't travel far and wide to locate one.
I have read about people changing out axles to be heavier duty, so I don't believe that was an unreasonable quest. Nor is rearranging the furniture. I actually came up with a plan for the smaller rig that would work quite well. Possibilities of changes create more options.
I always look at every situation with the mind set of, "Can there be improvements made? What can I do to make it better?" this is my personality, as was confirmed by the Meyers-Briggs personality profile. I am an ENFP. We think very deeply into "possibilities" and I have to explore every possibility! That is just how I am wired!
Everyone should take the test! It's quite interesting! And fun! It has helped us understand one another better!
TEST 1
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
