SabreCanuck
May 10, 2016Explorer
janegowest wrote:SabreCanuck wrote:janegowest wrote:
Thank you, Travelnutz, those figures are pretty obvious, and everything adds up, as the brochure gives the correct GVWR. I always thought that this is how you come up with the CCC...GVWR-UVW.
That is exactly how you come up with CCC. If the GVW of your trailer is 15000# and the UVW is 14049 then the CCC of the trailer is 951#. Simple. And probably printed on the yellow sticker of the trailer itself.
Yes..logistically, yes. But, in this case, they manipulated the numbers...particularly the GVWR to stay under 15K in order to meet CA requirements. Did you read that thread that I had posted a page back? That should help explain this insanity!
Yep, read it. That thread has two users mentioning the possibility that a manufacturer may have fudged the numbers to get under a CA law... I would consider hearsay.
To truly know the answer you should scale the trailer completely empty and you will know DEFINITIVELY how much stuff you can pack based on axle ratings and actual weight. But would be best to have YOUR (or similar) tow vehicle pulling it. The easier way of knowing that would be to go by the numbers on the yellow sticker on the trailer as a good baseline.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
