valhalla360
Jul 13, 2021Navigator
sc4r3d wrote:
Sorry for the lack of info, this is all new to me. It is difficlut to find info on Chevy's site, they like to keep everything secret, I have seen at least 3 different weights it can tow, etc.
option 1
Duramax® 6.6L turbo-diesel V8 tow 18,500 lbs. 5th wheel 18,510 lbs.
option 2
The Silverado 2500HD diesel engine allows for a max towing capacity of an astounding 15,400 pounds on properly equipped configurations.
Option 3 from their site.. so frustrating
2020 SILVERADO 2500 HD MAX AVAIL TRAILERING 18,500 lbs.†
MAX AVAIL TORQUE 910 lb.-ft.†
2020 Chevy 2500 HD LTZ 3.42 rear axle ratio
Crew Cab
6.6l Diesel
STANDARD BED
4x4
Fuel 362
GVWR 17,000 lbs
DRY WEIGHT 14,202 lbs
HITCH WEIGHT 3,640 lbs
CARGO CAPACITY 2750
Option 2
Fuel 352
GVWR 17,000 lbs
DRY WEIGHT 12,815 lbs
HITCH WEIGHT 3,060 lbs
CARGO CAPACITY 4137
5th wheels are almost always limited by the truck payload not the tow rating.
At 17k, a 25% pin weight pushes you up around 4000lb in the truck. Add in 200lb for the hitch plus passengers plus anything else you load in or bolt onto the truck (don't forget running boards and such). You could easily be over 4500-5000lb loaded onto the truck when ready to go.
Keep in mind with toy haulers, they start with higher pin weight when empty. When you put the toys in the back it reduces the pin weight and they don't want to leave the pin too light when loaded...so loading the trailer lightly doesn't necessarily help the trucks payload limit.
You can find your trucks actual payload limit by looking at the door jamb but I would want a diesel dually for either of those trailers. You might find a single rear wheel 1 ton that works but you will be pushing it to the limits and you won't be able to carry much of anything in the truck without worrying about being over the limits.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
