greatnate
May 28, 2020Explorer
jshupe wrote:
With 22" aftermarket wheels, you may want to check both the wheel and tire capacities as well. They're usually lower as your aspect ratio goes down. It's likely you derated your tow vehicle with that mod.
Shoot - yeah I didn't think of purchasing a toy hauler when I bought the Tahoe (I bought it with the wheels on there already). The maximum load rating on the tire is 2,337lbs per tire. Can you or someone who knows more about that than I do explain if that is enough? I'm thinking yes because the tires would be rated for even higher than the axle rating (axle rating in the rear is 4100lbs, front is even less).
About Fifth Wheel Group
