greatnate
May 28, 2020Explorer
Can I tow this? Rig Setup with statistics here
Hi Everyone - new to the form and I've been looking for a toy hauler that I can tow with my 2011 Chevy Tahoe Ltz 4wd with the HD towing/cooling package. Here are my stats:
Axle Ratio is 3:42
GVWR: 7300lbs
Max Trailer Weight: 8,200lbs
GCWR:14,000lbs
Max Tongue Weight (With weight distributing hitch): 1,100lbs
GAWR FRT: 3600lbs
GAWR Rear: 4100lbs
Curb Weight: 5,900lbs
Note: The Tahoe has the automatic load leveling in the rear and 22inch aftermarket wheels making the truck sit a little higher.
I've been looking at the Forest River Grey Wolf 19rr, here are its stats:
Dry Hitch weight: 574lbs
GVWR: 7574lbs
UVW: 4180lbs
CCC: 3394lbs
Length: 24"
I'd be looking at towing a ~1k lbs four wheeler and maybe another ~1k-2k lbs in other gear.
My math is as follows: Towing capacity will be fine even with the toyhauler maxed at its GVWR. However, I'm thinking the GVWR of the tahoe might be close to its maximum. As I mentioned the GVWR is 7300 minus curb weight of 5900 minus tongue weight of fully loaded toy hauler (15% of GVWR is 1,136.1lbs) and an additional 100 or so lbs for the weight distributing hitch means I'm at 163.9lbs remaining on my GVWR for the tahoe. Here is my dilema, I'm anticipating 500-600 lbs for the family which means I think I'm over the GVWR by a few hundred (300-400) lbs. Note: I don't normally expect to fully load the travel trailer. At most I'm thinking 1k lbs for my four wheeler and 1k lbs for any additional gear. With those figures I'm guessing I'm at roughly 6.6k-7k lbs on the travel trailer. Assuming I could reduce the hitch weight to 12% of the true loaded weight I'm figuring that would be a hitch weight of 792 (12% of 6,600 lbs, factoring in 420 additional pounds from the Unloaded trailer weight plus 2k lbs for gear and a four wheeler). Our math works out to be 7300-5900-100-792=508 leftover for items I can put in the vehicle. That means I'm right at my GVWR - I live in Wisconsin and don't plan on towing in the mountains in the future. Can you tow at a near maximum GVWR safely with 12% of the trailer weight on the tongue with a weight distribution hitch?
Edit: if this is too big, can you please recommend another toy hauler that will fit at least 1, 1klbs four wheeler and have a queen sized bed?
Axle Ratio is 3:42
GVWR: 7300lbs
GCWR:14,000lbs
GAWR FRT: 3600lbs
GAWR Rear: 4100lbs
GVWR: 7574lbs
UVW: 4180lbs
CCC: 3394lbs
Length: 24"
