- mountainkowboyExplorerI've always spun the wheel and tighten to about 10-15lbs. Then back it off to the next hole in the castle. Never had a problem.
- Gib3633Explorerda bees
Good one . I didn't recall saying my trailer had pinion bearings. I guess if you can't explain or answer a question you just try to make the other person feel dumb. - 2oldmanExplorer IIIf you want to avoid the nonsense use Youtube.
- da_beesExplorer
wildernesshd wrote:
no comparison between pinion bearings running with gear oil and trailer axle bearings running in grease. dont know how someone compare
I never realized 5ers even have pinion bearings,much less how to service them. Maybe they are one of those seldom heard of options that help with side winds and tail-heavy wag steering.:h If only I could find them,I want to check mine out before hitting the road again. - wildernesshdExplorerno comparison between pinion bearings running with gear oil and trailer axle bearings running in grease. dont know how someone compare
rtaylor0830 wrote:
when you repack bearings and you put hub back on i have heard you tighten down the nut to seat the bearings than loosen it, than retighten to finger tight is this the proper way.
Yes.
And then back off to the next cotter pin slot.
A pro will bend and cut the cotter pin in a unique way to create a signature when working on other people's stuff to know if you were the last one in there.- Water-BugExplorer II
da.bees wrote:
Gib3633 wrote:
I can't resist this one. Why does pinion bearings require approximately 55 inch lbs of rolling torque and axle bearings require free play all running in the same oil 2 feet apart? My obesrvation has been that pinion bearings out last axle bearings. Loose bearings beat themselves to death and cause seals to leak.
:? Your trailer has pinion bearings>?
It would be hard to stear without them. :) - da_beesExplorer
:? Your trailer has pinion bearings>? - wilber1ExplorerI've always tightened the nut and spun the wheel to seat the bearings then backed off the nut, tightened to finger tight then backed off until the pin would go in. Always worked for me, never had a wheel bearing failure after using this procedure.
- Cummins12V98Explorer III
Ig Dexter axles (or ?) go to their web site or call customer support. Then it is done right!
About Fifth Wheel Group
