kzspree320's avatar
kzspree320
Can tires have too much reserve capacity?
I had a blowout on my way home on Memorial Day. I had gone over 1,800 miles of our 2,000 mile trip and was getting close to home. Rear tire on passenger side blew. Got the estimate yesterday and damage about $3K. I never want this to happen again. I had checked the tire pressure and it was 77 psi (max 80) right before we left for home. Tire was a Goodyear Marathon 235/80/16 E rated tire with stated capacity of a little over 3,400 lbs.
Info on my fifth wheel is GVWR of 13,940# with 2 axles each rated for 6,000 lbs. Add the pin weight and you get to the GVWR. The E rated tires should be enough since the 2 tire ratings per axle are over 6,800 lbs. I want all new tires and am willing to spend to get good ones. My fifth wheel is a 2014 so my tires are not old but I just want all good rubber.
I see 2 decent options. Get the Michelin XPS Ribs or the Duravis r250 size 235/85/16. I have enough space so that's not a problem. The tires are only rated for 3,042 each, which is enough if both sides weigh the same, but I doubt that's the case. I normally weigh abut 12,500 ready to camp. Subtract pin weight and estimate 10,000 lbs on axles. That's just 2,500 lbs per tire if they are all equal, which I seriously doubt since the heavier appliances and reclining love seat are in one slide out on the same side as the bedroom slide. I actually think the tire that blew was on the light side of the camper.
The other option is to go to the Sailun S637 G rated tires with a rating of about 4,000 lbs per tire. Sure seems like overkill but maybe not. My rims are rated for 3,980 lbs and 110 psi (stamped inside rims). Seems like I could run about 100-105 psi and hopefully never have a blowout.
My question is this, "can you have too much reserve capacity on tires?" Would the stiffer tires place too much stress on the remainder of the suspension system, since a E rated tire might absorb more stresses than a G rated tire would.
I know there are a million of these tire threads and I have read most of them. All thoughts and opinions on this subject is welcome and appreciated. I need to make a tire decision soon. Thanks. Keith
  • stuff happens,theres tons of trash on our roads ,don,t really know why it went flat. pick a tire and move on.
  • Either the Duravis or the Sailun's will be a much better option than what you have.
    I have Sailuns aired to max. 110 PSI on a 14K GVW trailer.
    I'll take all the margin I can get.
  • Tire monitor, the best tires in the world, proper PSI, never go over 50 MPH, but you still could have a flat. You can't stop it if it wants to happen.
  • I run the R250's on a 3 axle trailer because they are steel casing construction. The sidewalls stand up rather than bulge like a balloon - exposed to damage. Tires on rearmost axles of a group are more subject to damage from road debris that is "stood up" by the lead tire running over it.
  • Ivylog's avatar
    Ivylog
    Explorer III
    X2 on spending the extra cost on a TPMS. You have no idea what the pressure or temp of the tire was before it blew. Many blowouts are caused by the tire getting to hot...overloaded or not enough pressure. One nail may have caused the $3.5K damage.
  • There is about as many opinions concerning tires, as there are threads about it. Not sure why you didn't air the Marathon to the full 80 psi, as that is recommended for most ST tires. Full pressure is needed for coolest running, less likely to blowout.
    Most run their TV tires at lower pressure, not towing, lighter load etc. Apples to oranges, truck and trailer. Now with many running truck tires on trailer, more opinions, more confusion. What if we put STs on our trucks? Would we run full pressure all the time? IDK
    Jerry
  • I'd prefer to have much more capacity than I have.
    I do have a tire pressure monitoring system. My rear inside duals go from 80 to 97 lbs after about 2 hours driving.
