ChooChooMan74 wrote:
As of right now, you are 340lbs over GVW/Payload capacity. Take it for what its worth, but the weight police hard liners will be all over that. For me, just be safe and run. I applaud you for taking the time to see where you are and actually weigh your rig.
Every pound you add to the bed will put you that much more over. Every pound you add to the trailer will affect the truck by a bit either putting more or less weight on it (unless you put it squarely over the axles, and all depends on where you put the weight.
Well, I was going to put a 125cc scooter on a carrier on the rear hitch receiver on the 5th wheel, and a few for miscellaneous items for about 150lbs in the truck bed.
Worried though that the scooter might cause a light pin condition. But too old to walk much, and would prefer not to use the truck for a grocery getter unless I have to.
It seemed strange to me that the GAWR for the trailer axles is 4400 each, which combined is less that the GVW. But I suppose that they take into consideration the landing gear when unhitched and the pin weight on the truck when hitched.
