Dano1955's avatar
Dano1955
Can You clarify my weights?
I've been reading here for awhile about weights and how they apply and I just had my first CAT scale weigh in, loaded with almost everything, but tanks empty.
For those with more knowledge/experience can you advise/clarify?
My Rig: 2013 RAM 2500 Crew SRW 6.7 Cummins, 5th is 2016 Prime Time Crusader Lite, trailer tires are load range E, more than needed for my rig, dealer put them on.
Truck sticker F 5500 r 6200 GVW 10000
5th wheel sticker
GAWR 4400 pin 1279 dry 7628 CCC 2392 GVW 10079
CAT weigh in
F AX 5100 D AX 5240 T AX 7380
I haven't weighed the truck without the 5th wheel, but I will get to that soon I hope.
I'm estimating to hit the road there will be 350-500 lbs more either in/on the 5th wheel or truck bed.
Not sure how to relate these specs to see if I'm maye pushing it farther than necessary.
TIA for any comments/suggestions.
  • As of right now, you are 340lbs over GVW/Payload capacity. Take it for what its worth, but the weight police hard liners will be all over that. For me, just be safe and run. I applaud you for taking the time to see where you are and actually weigh your rig.
    Every pound you add to the bed will put you that much more over. Every pound you add to the trailer will affect the truck by a bit either putting more or less weight on it (unless you put it squarely over the axles, and all depends on where you put the weight.
