eHoefler
Oct 10, 2015Explorer II
You can take it apart and clean it, but, most likely you have a bad impeller. You will need to replace it to make it pump. After every use, you need to flush it with clean water to clear it. I will pour in a little oil in it and run it to lubricate the impeller. If you don't lube it, the blades of the impeller will stick and when you try to run it, it can and will pull the blades off the impeller.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
