cavie
Oct 15, 2019Explorer
To drain the black and gray tanks look for a 3" black pipe with 2 t-handle valves. You may have two lines. I do. You also need to find the FW tank drain. It will be a 1/2" line with a valve on the end. You also need to find 2 low point drains. One for hot and one for cold. They will have valves or caps on the ends.
You tube is your friend. You don't need a manual. They are generac anyway. All RV are basically the same.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 24, 2026
