bpounds
Oct 17, 2019Nomad
Michelle.S wrote:
Is it possible the unit was setup on a seasonal site and the previous owner was plumbed directly and removed the holding tanks??
+1
Might not have ever had any.
Get underneath and find the tanks, if they are there. You will likely need to pull down whatever cover they used under the frame. But you'll want to do that anyway for inspection and as you work on the trailer. Waste tanks, if there are any, will almost certainly be under the floor and between the frame rails. Keep in mind that a fresh water tank could be under there, but also is often inside the trailer, under a bed, or a dinette seat, or other cabinet.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 24, 2026
