BAMS1215ExplorerAug 28, 2013Cargo door repair?What has been used to repair the door bracket for shock lift? The holes are loose and will not hold bracket. Thinking of making larger plate to distribute weight. Thoughts?
JohnBoyTooExplorerAug 28, 2013That's one way - tie the base plate to a larger plate...Could you 'resurrect' the screw hole with hollow wall anchor ?
Related ContentRepairing the cargo doorBroken cargo door keyside door bentRepair/replace cargo door (tailgate hole)Monaco Cargo Door
