What has been used to repair the door bracket for shock lift? The holes are loose and will not hold bracket. Thinking of making larger plate to distribute weight. Thoughts?
Those cargo doors are styrofoam core with a thin wood/plastic film,...this is what I did: The 6x8 3/16 aluminum plates cost me $20 to have cut at a machine shop, I used Sikaflex adhesive caulk for the adhesion, the screws were just to hold the plate in place while the adhesive cured. Been 3 years now, no sign of failure.
