Johndanielscpa wrote:
Ed, you're showing in your profile that Aqua Dulce is 70 miles SE of Los Angeles. If that's correct, you guys must have had a heck of an earthquake since the last time I was down there! It used to be about 45 miles NORTH of LA.
that was in I believe 1994 we were only slightly affected, but I was working graveyard in Burbank and it was strong and getting back and forth to work was a challenge, the night shift was helpful with less people.
PS if and when you take out the rug (which was easy, the flooring in front of the sink was another issue, as was the 110 degree day I picked to do the job.) get a sample to try and test the slideout.
