- ereed52ExplorerHehr part number location
Inside frame and/or window will need to be removed to fine part number.
Or remove inside frame measure hole and order new window. - VeebyesExplorer IIWe rode around for a couple of years with a cracked bedroom window.
Hunted all over for replacement window. No luck. Finally tried a small town mobile glass guy. He came to the CG, set up shop right there, 2 people, & in an hour for $200.00 the job was done.
The material used was lexan, not tempered glass. Extremely tough stuff. - PetethescotExplorer
Darryl&Rita wrote:
Damaged frame? Broken glass? Either way, find a glass shop instead of an RV repair shop. Brand is probably a Herh.
Can a glass shop replace the glass only in a frameless window? - banjoExplorerMine are Hehr. Don't know if Carriage used Hehr in 2006.
- Darryl_RitaExplorerDamaged frame? Broken glass? Either way, find a glass shop instead of an RV repair shop. Brand is probably a Herh.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
