MFL
Nov 12, 2021Nomad II
ford truck guy wrote:
As most are stating, it can be done.. The issue will be the factory receiver, MOST of them are rated for 300# carry capacity, or 3,000# tow capacity… that carry capacity would NEED to be beefed up..
There are a couple members on here that haul their HD’s on the rear end of their fiver…BUT ALL made modifications
Yes, like most, mine says 300/3000. Mine is reinforced with heavy square tubing, that I think is much more capable than 300 lbs tongue wt. I am thinking the manufacturers real issue, with this limit, is the FW suspension, and maybe reduced pin wt. In any case, I would never hang 500 lbs on rear.
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
