- klutchdustExplorer II
Grit dog wrote:
Sounds like some of y'all should fix the gas leaks on your "toys"....
I don't believe that it's coincidence that in 20 years almost of storing bikes and sleds in enclosed trailers, year round, I never have smelled gasoline fumes inside unless something was leaking or I was filling the tanks.
Me too. Before this TH with a fuel station i carried my fuel in jugs in the bed of my SxS. I had no smell inside the trailer. - lincsterExplorer
Huntindog wrote:
lincster wrote:
LOL. Close.
Wow. Are you going to Antarctica or something?
I would just go buy fuel and/or propane.
The north rim. The highway in has a locked gate. Propane and gas may or may not be available without a long drive. Basically we need to take what we expect to need with us. I hate to waste a day running around after supplies.
I once had the propane regulator fail at the begining of a hunt there. Temps were in the low teens, and no propane getting past the regulator meant no heat. I had to run into Flagstaff to get a new one. That wasted an entire day, and a lot of fuel. I now carry a spare.
I totally get carrying spare parts.
I used to live in Page so I know the area you are talking about. - HuntindogExplorer
lincster wrote:
LOL. Close.
I once had the propane regulator fail at the begining of a hunt there. Temps were in the low teens, and no propane getting past the regulator meant no heat. I had to run into Flagstaff to get a new one. That wasted an entire day, and a lot of fuel. I now carry a spare. - lincsterExplorerWow. Are you going to Antarctica or something?
I would just go buy fuel and/or propane. - naytherExplorer
Dirtclods wrote:
valhalla360 wrote:
Look at killing all the 12v in the house (even if the gas is in the toy's tank). I wouldn't trust these devices to be ignition protected.
Obviously, you need to keep brakes & brake lights connected.
Look at killing all the 12v in the house (FRIG) = Runs off the house batteries.
That's just silly. that post was from a non-toy hauler I'm sure. - HuntindogExplorer
wopachop wrote:
I have done a lot of automotive AC work. As result, I have an awesome O ring collection.:BHuntindog wrote:
I hear you. Typing this inside a toyhauler sitting in the garage/dining area. Gas cans can seal really good. If yours dont you can buy the big black oring for the main cap. If the little vent doesnt seal you can probably buy that as well. I recommend buying the green nitrile oring set from harbor freight. That set has saved me so many times. I fixed a darn leaking kureig coffee machine once with them. There is a size that works perfect for the gas can vent.wopachop wrote:
The toys come out at camp. The garage becomes a dining/sleeping area
Only issue will be smelling gas if you need to sleep in the toyhauler with toys in it.
The toys actually have a vent that can fail. Its supposed to allow air into the gas tank, but not let fumes out. Ive had to sleep in my trailer with toys in the garage and its not fun. Those fumes are no good. My trailer has a front bedroom and even with the doors shut and windows open i will taste gasoline in my mouth for days.
Point being gas cans should seal 100%. Storing them inside your toyhauler is no big deal if done safely. Ive read the plastic itself is pourous. So its horrible for long term storage. But traveling with a common 5g gas can inside the toyhauler is very common. - HuntindogExplorer
lincster wrote:
The bed already has B&W Companion, and 60 gallon aux. diesel tank. I am bringing 5 spare propane tanks, and then will fill the rest of the bed with fuel.
I don't do this.
I put my extra fuel in the bed of my truck.
I carry 60 gallons in cans in the bed and still have plenty of room for wood etc.
If it all fits, great. If not it will go in the garage. I have good fuel jugs that seal tight, and will open the garage vents.
This is a pretty long stay for us. We will on shorter stays top 1000 miles on each of our two quads. At 25 MPG, that is 80 gallons right there. It will likely be more than that this time. Perhaps 120 gallons Then there is generator fuel. That can vary a lot depending on the weather. A minimum though is likely a gallon a day. So at least another 20 gallons. Triple that in bad weather. Total is likely 140 gallons in good weather 180 gallons in bad weather. The Momentum tanks hold 60 gallons. So worst case we would need 120 gallons more. I only have 85 gallons worth of jugs though. Hope the weather isn't bad the entire trip. - Grit_dogTrailblazerSounds like some of y'all should fix the gas leaks on your "toys"....
I don't believe that it's coincidence that in 20 years almost of storing bikes and sleds in enclosed trailers, year round, I never have smelled gasoline fumes inside unless something was leaking or I was filling the tanks. - wopachopExplorer
Point being gas cans should seal 100%. Storing them inside your toyhauler is no big deal if done safely. Ive read the plastic itself is pourous. So its horrible for long term storage. But traveling with a common 5g gas can inside the toyhauler is very common. - lincsterExplorerI don't do this.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
