- lots2seeinmyrvExplorer
johntank wrote:
lots2seeinmyrv wrote:
We just bought ProFlex clear caulk at camping world. Haven't started the project yet.
The guy at camping world told us to do one panel at a time, big job to try and do all at once.
Remove the old caulk, use denatured alcohol with a clean cloth to clean the area. Apply the caulk in very small sections and use windex on your finger to smooth it down. He said don't try a run a really long bead all at once.
I will add this, use painters tape down both sides that you will be caulking this will limit the area the caulk spreads out as you smooth it down.
Thanks for the tip! - johntankExplorer
I will add this, use painters tape down both sides that you will be caulking this will limit the area the caulk spreads out as you smooth it down. - DuckExplorerCall the factory and use what they use if possible. Some caulks do not adhere to other brand of caulks.
Don - Lenny_KExplorerProFlex is definitely the best way to go. Been using it for years.
- lots2seeinmyrvExplorerWe just bought ProFlex clear caulk at camping world. Haven't started the project yet.
Remove the old caulk, use denatured alcohol with a clean cloth to clean the area. Apply the caulk in very small sections and use windex on your finger to smooth it down. He said don't try a run a really long bead all at once. - filrupmarkExplorerDont use dap. Choose a quality RV caulk. Been there done that.
- cruz-inExplorer3m 4200 UV
Expensive but truly exceptional long lasting caulk. It is designed for the harsh Marine environment. - alcaracuExplorerpro flex. al c.
- therinkExplorerGoogle Eternabond clear RV caulk
- B_SjulestadExplorer II
JIMNLIN wrote:
Caulking a new 2014 trailer already ??
I would first check with the trailer manufacturer and see what they recommend. That way they can't say you used the wrong type of product.
no, I was just wanting to know for when that time comes. thanks for the quick replys
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
