therink
Apr 28, 2014Explorer
I would start by saying that you appear to have a severe case of delamination caused you one or more water leaks at the rear roof/end-wall seam area. Water gets in behind the thin filon layer and breaks down the glue and causes the filon to separate
from the thin "cardboard" backing material.
You will likely need to remove and replace the entire rear wall. First you need to identify and repair the leak source.
Do a search on this forum for "delamination repair" and am certain you will get some ideas.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
