RoyB
Jan 12, 2017Explorer III
Look around near the main TV setup and see if you can find this WALL PLATE panel... This could be mounted under a shelf, on the wall, or even inside a a cabinet door...
Google Image
This is the panel that switches 12VDC Power ON-OFF to the BATWING OTA Antenna mounted on the trailer roof where a BOOSTER AMPLIFIER is installed in the base of the BATWING antenna. It will have the name WINEGARD on it and you will see a small LED push button on it...
Google Image
I have no idea what the very new trailers use for the Over The Air HDTV reception so it could be your trailer incorporates something else...
This would be the only so called "SECRET" switch I can think of for switching from CABLE and OVER-THE-AIR TV reception.
Roy Ken
Google Image
Google Image
Roy Ken
About Fifth Wheel Group
