donn0128
Nov 29, 2013Explorer II
Me Again wrote:donn0128 wrote:
Cedar creeks are heavy on the pin. Expect about 25% of the trailers actual weight. Lacking that figure 25% of the trailers GVWR. And NO a 2500 series is not enough truck if you asking.
Set of air bags on the rear of his 2007.5 RAM and he should be good to around 3K in the bed. Hitch, gear, and pin weight. Except for the rear springs the 2007.5 2500 and 3500 SRW trucks were actually the same.
Chris
I believe you will find that the rear end is different. My dually has a 11.5 inch AAM rear axle, and I believe the 2500/3500SRW has a 10.5.
Besides that tires and wheel capacity is less. BT-DT and his 2500 simply is not going to be enough to do the job pulling into or out of central Oregon
About Fifth Wheel Group
