Xflyhighx's avatar
Xflyhighx
Ceder creek champagne
does a 2019 ceder creek 38EL have disc brakes
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post your topic in the RV Forum which corresponds to the subject of your topic. Thank-you!
  • Moved from Forum Posting Help and Support
  • From the Forest River site -
    SUPERIOR PERFORMANCE
    Dexter® Axles/Brakes Suspension For Performance and Safety
    Nev-R-Adjust® Brakes are always properly adjusted for improved stopping power in half the distance
    E-Z Flex® rubber equalization system with 1/2” link plates and eight grease zerks per side
    Heavy duty axles with bronze bushings in shackles (No plastic bushings like our competitors)
    17.5” 8 Lug, ST “H” rated tires on 8000 lb. Dexter® Axles
    STANDARD FEATURES
    Nev-R-Adjust® brakes
  • I believe it uses the Dexter Nev-R-Adjust drum brakes.
    Tom
