ford_truck_guy's avatar
Jan 25, 2020
Ceramic - VS - Semi Metallic
This has been debated many times on this, and other forums. With many upgrading their fivers to discs, it may be a good read if your unsure of the differences.
Is the article correct, ?? who knows, you decide :B
I already know which way I go, enjoy your read...
Ceramic - Semi Metallic
  • When converting to Kodiak disc brakes, is it better to go with the slip on rotor type, or the integral hub/rotor.
    I read somewhere that the slip on rotor was for surge brakes only.
    Thanks
  • Stacy_Hughes wrote:
    i Will Go by Ceramic as it is Quieter than semi-metallic pads and
    They produce less dust,durable than Other pads.
    For what application and what product?
  • i Will Go by Ceramic as it is Quieter than semi-metallic pads and
  • oldbird1965 wrote:
    So are you saying the EBC Yellow #DP41240R are a direct replacement for the NAPA UP-7136-M? I realize my 08 DVR with 8K axles is a lot older then yours but also looking for more braking power.
    YES that is the same NAPA number I ran on my 07.5 MS and installed within a couple months on my current 16 MS. Originally the NAPA pads were US Made but now are Mexico.
    The EBC says right on the box Buick Century.
    Here's the Timken bearing numbers 25580 and 02475.
    If a person wants to go to Oil Bath on the newer Kodiak 8k system as I did this is the PROPER seal for doing so that does NOT leak. National 370219A
    I run EBC on my Harley, they are aWESOME!
    I upgraded my 01 RAM Sport to the Orange HD Towing EBC's and the difference is incredible.
    I changed to the same Orange on the front of my 15 DRW RAM, The difference is incredible. They did not have rears in stock at the time. when I get to my home base rears will go on. I am sure the difference will be even more dramatic.
    ALL EBC products are expensive and WELL worth it based on my personal experiences.
  • So are you saying the EBC Yellow #DP41240R are a direct replacement for the NAPA UP-7136-M? I realize my 08 DVR with 8K axles is a lot older then yours but also looking for more braking power.
  • To be clear the AWESOME pads are the EBC Yellow. The NAPA semi metallic were better than what Kodiak “ceramic” supplied for sure but these EBC are far better.
    And thanks again for the pads!
  • Cummins12V98 wrote:
    Ceramic = NoBueno!
    The ones that say Ceramic look closely they state "Ceramic like" as in low dust.
    These are expensive but i can tell you from personal experience they are AWESOME!!! 1,300 miles on mine, RV has never stopped better comparing to stock Kodiak pads or NAPA's best Semi Metallic.
    EBC Yellow #DP41240R These are the ones that fit MORryde 8k IS System or Kodiak 8K disk system.
    Thats what is stopping my Redwood, and when I change them out I have 2 sets of EBC Yellow ( price mis marked on Amazon ) ready to be put on.
    Shipped on November 11, 2019
    Items Ordered Price
    4 of: EBC Brakes DP41240R Yellowstuff Street and Track Brake Pad
    Sold by: Amazon.com Services LLC
    Condition: New
    $17.06
    Shipping Address:
  • Ceramic = NoBueno!
