- down_homeExplorer IIMatch pads to rotors. AMG brake rotors are relativ4ly soft and pads to match.
If you to pads harder than the rotors are matched with you will eat up the rotors and so on faster.
if you can find any get real heat treated then cold stabilized rotors and pads to match. Not sure where to start except Internet. - MrWizardModeratorDid the brakes this past Tuesday , four days ago
Replaced pads with new semi metallic pads
So far working good - atsrmfExplorerReplace with OEM pads, take the guess work out of the equation.
- Chum_leeExplorer
MrWizard wrote:
getting ready to do the front brakes on my 1997 F53 Bounder
I'm thinking ceramic is better for heat dissipation on a heavy MH
right or wrong ? pros/cons ?
Everything is a trade off. If your pads last longer but your rotors wear out sooner, what's the best answer for you?
If the pads wear faster, the brakes work better but wear out sooner and the wheels load up with dust, what's more important to you?
If every time you touch the brakes it sounds like fingernails on a chalkboard, but the brakes/wheels stay cleaner, for longer, and last forever, what's better for you?
I could go on forever, but . . . . . .
The OEM's (vehicle manufacturers) usually select materials that generate the least phone calls (read service complaints) for them. Their experience (which came from building/servicing millions of vehicles like yours) helps them decide what comes with your vehicle when it is delivered new. How you decide to change it (if at all) is up to you.
Chum lee
No one has mentioned it so far, but if you are having trouble with your brakes overheating, you could also consider using cross drilled and and/or slotted rotors (or both) with various pad combinations. Before you throw parts at the issue, if you have one, finding out WHY you have a brake overheating issue is advised. After all, you are already driving a heavy duty truck chassis with very large brakes. - John_WayneExplorer IIuse what's easiest on the rotors pads are a lot cheaper to buy then rotors, and easier to change.
- Wills6_4_HemiExplorer
dodge guy wrote:
Same thing for me, I run ceramic pads on all my vehicles except my 2016 dodge 3500 due to not needing to change with only 20K miles but when needed the will be ceramic.
Ceramic pads on all my vehicle. No issues with noise. All stop excellent and no filthy wheels! Even my X stops better! - dodge_guyExplorer IICeramic pads on all my vehicle. No issues with noise. All stop excellent and no filthy wheels! Even my X stops better!
- C_B_Explorer II
garry1p wrote:
I put on the ceramic and like others no dust however no noticeable stopping distance and they ate the rotors.
Went back to semi-metallic pads.
X-2
C.B. - garry1pExplorerI put on the ceramic and like others no dust however no noticeable stopping distance and they ate the rotors.
Went back to semi-metallic pads. - SidecarFlipExplorer IIIBeen my experience that ceramic pads tend to eat the rotors up faster and they squeak.
38,780 PostsLatest Activity: Aug 05, 2026
