JIMNLIN
Jan 02, 2019Explorer III
I jack the axle tube next to the U bolt on my triaxle GN stock trailer and all my other triaxle GN fladeck trailers I've had in service. All I'm lifting is one end of a axle just enough to change a flat tire or service work. I've jacked axles from 1750 lb on up to 8k lbs.
My old 12t shorty hydraulic truckers special is made for jacking one end of the axle on std spring suspension trailers. The top of the jack has a short leg U channel adapter that fit the axle
Agree with others on jacking both end of the center axle off the ground can flip the spring hangers if its raised high enough.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
