- George3037Explorer
Rockinfigs wrote:
George3037 wrote:
I use a $30 portable 2 ton floor jack available from Harbor Freight or most any hardware store. I've had a bottle jack kick out too many times due to weight shifting while lifting under a round axle. The floor jack is small and light enough to carry in my storage compartment and feel it is much safer.
Yeah I was leaning towards the floor jack idea because of the reason u mentioned the surface of the bottle jack on the curved axle I don't feel safe. Is the 2 ton jack enough to lift the axle?
I last used one on mine to replace tires. I only have a double axle but empty weight of my TT is 7269 lbs. Loaded weight is 11,170. With the 2T jack I'm not lifting the entire TT, only lifting an axle with some trailer weight high enough to get the wheel off. - RockinfigsExplorer
firemedic1992 wrote:
Do you have the Lippert auto level feature (6 hydraulic jacks)?
If so I’d lift the trailer with the jacks to change the tire.
Yes I do.. I have the 6 point hydraulic... I also thought about this but I thought I read somewhere not to use it to change tires.. - RockinfigsExplorer
Yeah I was leaning towards the floor jack idea because of the reason u mentioned the surface of the bottle jack on the curved axle I don't feel safe. Is the 2 ton jack enough to lift the axle? - firemedic1992ExplorerDo you have the Lippert auto level feature (6 hydraulic jacks)?
If so I’d lift the trailer with the jacks to change the tire. - George3037ExplorerI use a $30 portable 2 ton floor jack available from Harbor Freight or most any hardware store. I've had a bottle jack kick out too many times due to weight shifting while lifting under a round axle. The floor jack is small and light enough to carry in my storage compartment and feel it is much safer.
- ependydadExplorer
- eHoeflerExplorer IIPlace your bottle jack directly under the U-bolt.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
