sheff69 wrote:
recycler wrote:
i would see about upgrading your wiring and installing new drum system is lots cheaper and easier to maintain..
It might be, but it is nowhere near as efficient.
In over 30 years and numerous trailers, with reasonably heavy trailers, I've never been able to lock up drum brakes in a panic stop.
With my Kodiaks, I can. I'd rather flat spot tires than repair damaged truck front ends.
I've always maintained my own brakes, and I'd much rather work on greasing slide pins on disk brakes, than trying to adjust drum brakes.
Sheff
Sheff I believe if you research it, that max braking occurs at a point just before the tires lock up and skid. Once the skid starts breaking power goes down quite a bit. That is why modern cars and trucks have anti lock brakes, plus the handling issue.
I trailer with locked up brake is more likely to come around on you and flip on it's side.
So lock up is not GOOD!
Chris
