Artemus Gordon wrote:
Only real difficulty is choosing the light output you like. Also realize if any lights are on dimmer switches, you must use special LED Lights. Otherwise the hum will drive you batty!
Are any of the 12v bulbs made with the twist lock bases. Most posts I have seen here are from folks that use the stick on with harness that plugs in to the fixture socket.
Am doing a gradual conversion to LED in the stick n' brick. Fed up with the CFL's, they just don't seem to last, especially those fancy vanity bulbs we use in one bath. Was pleasantly surprised by the LED light intensity. I swear the bright white rated equivalent to a 60 watt incandescent bulb puts out more light than an incandescent. Been buying them from HD, manufactured by Cree in North Carolina and have a 10 year warranty. Oops, thread drift........:o
